Supercharging FAQ
  • 1 month later...
  • Replies 104
Popular Posts
Until you try some good brakes, you have no idea how bad the standard ones are :-) Don't get me wrong, we don't all have deep pockets, but seriously......4 pots and 330mm discs are what high performan
Ok I managed to find it. Just Fyi all the last digits on the pulley are diameter in inches and VF tell me they are:
MK3 Stage 1 & 2. The stage 1 pulley is a 3.25" and the stage 2 is 2.87"
so for example my PN is 2A037-287 (Easy when you know how eh!!! :) )
So as I know there have been a couple of guys with the wrong pullies in the past this is how to check....
I hope it helps poeple out there
Cheers
  • 1 month later...
I have also managed to steal this off someone else on here who has managed to find information.
http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?222242
found it!
And for reference:
3.25" Pulley
Boost up to 6-7 psi
3.12" Pulley
Boost up to 8-9 psi
2.87" Pulley
Boost up to 10-11 psi
2.75" Pulley
Boost up to 12 psi
2.62" Pulley
Boost up to 13 psi
2.5" Pulley
Boost up to 15 psi
  • 1 month later...
I didnt know there was a 2.5" 15psi pulley, I thought the max was 12psi? would the smaller puller generate more belt slip than the other?
Also, why do no charged VRs running toothed belts like you see on G60s and G40s?
  • 3 months later...
Right I'm on my way to a rebuild now but the only way I'm likely to do it (as saving up everything in one go isn't going to happen!) is for me to buy the parts needed myself bit by bit and when complete get someone to do it all.
I'm unsure on everything I need though, as well as what else is worth doing whilst its been rebuilt.
Aim is for a rebuilt engine to take a stage 2 s/c reliably.
Parts I'm aware of that need replacing/worth repacing whilst the works done.
Pistons - My block will be re-used and rebored to a 'true' (is it???) 2.9, not sure on size I'd need but thinking about JE Pistons?
ARP Rod & Head Bolts - Where can you get these from?
Valves & 268 Cams - Want the head rebuilding too.
------ Still stuck on what I need for a rebuild. Help! ------
Clutch & Flywheel - Probably worth doing at the time, been told a Standard VR6 clutch can take a Stage 2 easily.
Radiator - Mines fine but a fair few years old so think i'll swap this too
Hoses - Already got a Samco Hose set waiting!
Chains/Tensioners/Water Pump - Again, prob worth doing at the time
Exhaust - Already got a Milltek Sports CAT waiting, just need the cat back system now.
General Service Items - Obviously!
Ok, what else?
I'm unsure on everything I need though' date=' as well as what else is worth doing whilst its been rebuilt.
Ok, what else?
If I was doing another 12valve I would avoid JE pistons and buy Wossner jobbies, you will need 83mm which will give 2937ish CCs.
ARP head studs and rod bolts I got from Summit Racing in the US.
I would avoid going 268 cams also, the Schimmel 263s are what you want.
You will need fuel injectors, a 4 bar fuel pressure regulator, decent 6 branch as for the clutch I would opt for a helix or similar for the sort of power you want.
If I was doing another 12valve I would avoid JE pistons and buy Wossner jobbies' date=' you will need 83mm which will give 2937ish CCs.
Alex mate would you say all these things are necessery for a stage 2 or would they be a good idea only if you are going for a total rebuild ?? Just a bit unsure about what else I should be doing at the same time ?
Lets be honest about supercharging, the Rotrex chargers are the only chargers that will give you real power. They are a little more to buy but you will have far more scope to tune for more power when you want it. I ran 27psi at one point which is unheard of with a Vortech. There is a few guys on here that have seen the light or gone down the turbo route.
These sites have all you need to know:
http://www.rotrex.com/
http://www.stormdevelopments.co.uk/powered-by-rotrex.html
If you want the best results both on the road and on the rollers then the answer is yes Ben. There is much more stuff I could add and if Im honest an oil cooler isnt one of them!
Yeah would rather do it right and not have any probs and get it runny sweet. Looks like I had better do some more research and get the credit card out again !!
Tell me what youve got already and I will tell you what you need and where to buy it! I mean every little part no matter how small! You going Vortech?
Cheers mate - no have bought a stage 2 z-engineering kit from a mate on e38 - which he says comes with rising rate fuel pressure reg, and fresh belts, oil catch tank, piping and hosing. Everyuthing you need to get it running in your car.....its all plug and play. Also comes with a boost guage thats been integrated into the vent. So really just wondering what else I should do at the same time to make sure my engine can cope ? The engine is only on 90,000 miles I have have the head gasket and chains done about 9000 miles ago and the engine runs sweet at the mo.
As long as your engine is healthy you should just be able to bolt that kit on and just chill out, No need to rebuild your engine or anything like that, I think lizard racing is more on about really big power builds, I think eat this and xyber are both running stage 2 and above on standard engines???
