you need a piston winding tool really, but if your strong as fcuk, you can sometimes get them in with a pair of long nose pliers and a bit of elbow grease. It's a bit yeehaw though!!
If your car is modified and you want to stop quicker, uprate the lot, otherwise just stick with the standard set up.
Search the previous threads too.
Fronts need pushing in, I usually just use a G clamp.
The rears you need to wind in using the wind back tool, about £15 from GSF. Its quite a few turns i THINK, i remember it took a little while even with an impact gun.
I run stock disks all round with pagid fast road pads. Stops rather well!!!
  • 3 weeks later...
