dom.joy 87 Posted August 4, 2015 Report Share Posted August 4, 2015 Any tips for replacing the gearbox mount? I tried removing the three bolts and taking the bracket off but one of the bolts fouled and wouldn't come out.Is there a way without dropping the subframe? Link to post Share on other sites
bennyk 1,238 Posted August 4, 2015 Report Share Posted August 4, 2015 Are you jacking the engine up at all? Don't remember this being a problem on mine Link to post Share on other sites
dom.joy 87 Posted August 4, 2015 Author Report Share Posted August 4, 2015 Yeah a little. Did you remove the bracket or just jack it enough to swap them out? Link to post Share on other sites
bennyk 1,238 Posted August 4, 2015 Report Share Posted August 4, 2015 I think you can get away with just jacking it up, little tip though unplug your main fan or you might snap the plug! Link to post Share on other sites
dom.joy 87 Posted August 4, 2015 Author Report Share Posted August 4, 2015 Ah cheers for the tip. Think I'll remove that and the inlet as it was getting closer to the brake fluid reservoir. Although the fan plug is already in bad shape Link to post Share on other sites
dom.joy 87 Posted August 10, 2015 Author Report Share Posted August 10, 2015 Cheers for the help, got this changed at the weekend. The one that came out was pretty bad. Link to post Share on other sites
