VR6Pete 1,456 Posted November 6, 2014 Report Share Posted November 6, 2014 Soooo. Seems my sounds in my corrado is rubbish and have no bass!I'm not after a sub or anything but would like some better speakers for my rear parcel shelf supports, doors and dashboard. As these all look like original components. What's available that's ok without going mad?Does anyone Have any recommendations? Naturally I'd need to know sizes etc.. Cheers guysPete. Sent from my iPhone using Tapatalk Link to post Share on other sites
The Duke 27 Posted November 7, 2014 Report Share Posted November 7, 2014 I don't know a lot about ice but do know if your not running a sub and want improved bass 6x9's are good (not as good as using a sub but you know what I mean) you could use a stealth shelf if you want to keep it looking clean. I've used infinity kappa in my mk3 and always thought the were good. Link to post Share on other sites
VR6Pete 1,456 Posted November 7, 2014 Author Report Share Posted November 7, 2014 No way am I butchering my corrado parcel shelf im only looking to upgrade my standard existing components Sent from my iPhone using Tapatalk The Duke and damian8588 2 Link to post Share on other sites
CALICO 130 Posted November 7, 2014 Report Share Posted November 7, 2014 Youll need to know the size of the speakers your replacing. Go with something about 120-150watts if you going to amp them all otherwise 50watts then add a 12" sub . The sub will make the biggest difference Link to post Share on other sites
stuarttaylor37 4 Posted November 7, 2014 Report Share Posted November 7, 2014 (edited) Amp, audioscape pods and 10" sub gives a really good soundIve tried uprating original speakers and it was better.... but not much Edited November 7, 2014 by stuarttaylor37 Link to post Share on other sites
Mk3highline 287 Posted January 25, 2015 Report Share Posted January 25, 2015 Not sure how different the door cards are in your corrado but dynamat or some thing similar to stiffen up the cards, I'm no expert but what I did was get some foam around 20mm thick and wedged it in between the metal and for cards to stiffen them up which give some more mid bass up frontTo check play some bassy tunes loud and feel the door cards if they are vibrating loads what I said will helpAlso choosing mid bass speakers is key I can't find the link but you need to look at the QTS and Fs etcDon't just buy a named expensive brand there are some good reasonable priced speakers out there that will some wicked if your front doors are seeled and don't vibrateiv got some nasty edge speakers in front doors standard tweets pointing towards the Center mirror standard in back doors and disconnected the rear tweets and a massive 8' alpine sub lol Long winded by it's Sunday and I'm bored Also the alpine sub is 120w rms and I'm putting 900w rms through it crossed at 34hz and sub box is tuned to 29hz Link to post Share on other sites
Mk3highline 287 Posted January 25, 2015 Report Share Posted January 25, 2015 This link has some info there is another some where http://www.mobilesoundscience.com/showthread.php/669-Ideal-parameters-for-midbass-drivers-Qts-Fs-etcI had some JL 6x9 on a mdf stealth shelf got little bass but sound stage and imaging was sh1t Don't know the size or the rear speakers in a corrado but earthquake make some 6.5 http://www.earthquakesound.eu/car-audio/sws-subwoofers/sws-65x.aspxThese are going in my rear doors with an amp for mid bassOnce engine is working as it should Link to post Share on other sites
Mk3highline 287 Posted February 7, 2015 Report Share Posted February 7, 2015 http://www.the12volt.com/installbay/forum_postsm.asp?TID=100789Half way down shows the solution Link to post Share on other sites
