paceo 22 Posted October 21, 2014 Report Share Posted October 21, 2014 hi guys, ive got a standard compression tester for my golf vr6, now obviously this wont determine if its a worn cylinder head or bottom end as the car is a bit smokey (blue - oil) with a compression tester i will do the test first when the engine is warm, then add a bit of oil to the cylinder again, if it rises a lot i believe thats the case for a worn piston ring? how much oil in ML do i need to add? or has anyone got a leak tester local to bromley in kent who wants to pop over and earn some ££ :grin: Link to post Share on other sites
michael5556 247 Posted October 21, 2014 Report Share Posted October 21, 2014 Hello, when you do your compression test, they should all be within 10% of each other. If not then there is your problem.... As for the oil, just a small amount such as a spoonfull or eggcup... After that a leak down test as youve mentioned would be wise. Link to post Share on other sites
paceo 22 Posted October 28, 2014 Author Report Share Posted October 28, 2014 Hello, when you do your compression test, they should all be within 10% of each other. If not then there is your problem.... As for the oil, just a small amount such as a spoonfull or eggcup... After that a leak down test as youve mentioned would be wise. read this mike, what do you think? i added just under a tablespoon http://www.vr6oc.com/forum/topic/45474-results-from-my-vr6-dry-wet-compression-tests/ Link to post Share on other sites
