novice1976 2 Posted September 2, 2014 Report Share Posted September 2, 2014 Hi allI have just noticed an oil leak (gearbox end) on my 95 vr6 golf and after replacing sump gasket the leak is still there.Im about to remove the gearbox and would like to ask if the flanges on the driveshaft going into the box need to be renewed as will be draining box oil as been told easier to remove both shafts.cheers robPs Im a complete novice to golfs so any help would be great. VR6Pete 1 Link to post Share on other sites
VR6Pete 1,456 Posted September 2, 2014 Report Share Posted September 2, 2014 I would replace those and crank seal too mate Link to post Share on other sites
Lukey. 381 Posted September 3, 2014 Report Share Posted September 3, 2014 It's easier to remove the diff cups to get the box out yes, but it's not necessary, I didn't on mine and it took a bit of to and fro but did it in the end, make sure you can get the fill hole out if the box before you attempt anything though. If you can't get that out you won't be able to put any new oil in. Link to post Share on other sites
novice1976 2 Posted September 3, 2014 Author Report Share Posted September 3, 2014 Thanks for the help guys I will attempt operation gearbox at the weekend so fingers crossed.Cheers Rob Link to post Share on other sites
