Fitted c2 #42 chip now won't idle,
As a title says I have swaped my vrt to obd2 ,on standerd ecu it started and idled perfect,I then put my c2 chip in and now when it starts it cuts out unless I hold the revs to 1k ish,
Should the throttle body be re adapted to suit(how do I do this?) or do I have a bigger problem?
I have no fault codes appart from lambda as it is currently disconnected,
Thanks
