Hi all,
As i will be changing my door cards to leathers, i want to make the most of the job and though about putting something like dynomat inside the doors, should stop a lot of that hollow noise you get off the engine and make a more satisfying noise when you shut the door.
Has anyone ever done this before? Any tips or advice? Also aby recommendations on what materials you used and what the result was.
Thanks,
Dave
At first i thought you were joking luke, but then i suppose it does make sense, suppose there wont be any weight differences? How hard is it to apply, as you would have go in from the bottom where the window mech is and reach up?
