Dekerf1996 27 Posted June 11, 2014 Report Share Posted June 11, 2014 My charged VR is sounding a liitle sick and being on 105k looks like its the timing chains need replacing. THe engine is also breathing a little heavy from the cam breather pipe. So planning to wip the engine out, and fit new chains, guides etc, make sense to chuck on a new clutch and headgasket whilst i am there i think, enabling me to run a spacer plate to drop the compression a touch, so i can up the boost :-) Now as i will have the head off, i might as well get it a good going over, skim and new valve guides. Is there anything else thats recommended whilst this is being done and is it best being done by a machine shop that knows about VR engines or can any shop do this? Can anyone recommmend a shop around Reigate in surrey (J8 M25) to do the work Link to post Share on other sites
cactusjackslade 146 Posted June 11, 2014 Report Share Posted June 11, 2014 If its breathing heavy and high mileage might be worth going that little bit further and checking piston rings and bores for excessive wear.... Link to post Share on other sites
Dekerf1996 27 Posted June 11, 2014 Author Report Share Posted June 11, 2014 I am going to look at the bottom end too, hopefully it's not that. I have a problem with the loom to the blue temp sensor and it thinks it has a problem, hopefully it's that, that's causing the problems, otherwise this could get expensive :-(Sent from my iPhone using Tapatalk Link to post Share on other sites
Dekerf1996 27 Posted July 18, 2014 Author Report Share Posted July 18, 2014 Nobody recommend a machine shop around here to work on my VR head?? Link to post Share on other sites
VR6Pete 1,455 Posted July 20, 2014 Report Share Posted July 20, 2014 Can highly recommend stealth racing but might be a bit too far for head rebuilds Club Chairman Link to post Share on other sites
abvsean 32 Posted July 22, 2014 Report Share Posted July 22, 2014 if your able to pull an engine out im sure you could sort the head yourself. Link to post Share on other sites
Dekerf1996 27 Posted July 22, 2014 Author Report Share Posted July 22, 2014 Well things have escalated now, got a dead bottom end too :-(I could do some of the refresh myself, but it needs skimming, so might get it all done together :-) Link to post Share on other sites
Sump_slammer 23 Posted July 22, 2014 Report Share Posted July 22, 2014 How did you get to that conclusion? Link to post Share on other sites
Dekerf1996 27 Posted July 22, 2014 Author Report Share Posted July 22, 2014 Well it's breathing heavy through the crankcase breatherSo took it for a compression test and1. 2. 3. 4. 5. 6. 175. 142. 138. 172. 159. 161Leak test1. 2. 3. 4. 5. 6. 50%. 55%. 65%. 20%. 20%. 20%And when testing it was leaking so badly it was coming back through many different point and other cylinders when doing it Link to post Share on other sites
paceo 22 Posted October 7, 2014 Report Share Posted October 7, 2014 did you ever get the engine sorted? Link to post Share on other sites
Dekerf1996 27 Posted October 15, 2014 Author Report Share Posted October 15, 2014 Still working on it, new Pistons in the post, should be here tomorrow.Hopefully go off to engine builders after that. I had troubles finding an engine builder that didn't have a 2-3 month wait, thoughi may still go with one of those, still haven't decided Link to post Share on other sites
Jimjon 28 Posted October 15, 2014 Report Share Posted October 15, 2014 When you get the head skimmed you should get the upper timing chain cover that bolts to the head skimmed at the same time, just in case you didn't know. Dekerf1996 1 Link to post Share on other sites
Dekerf1996 27 Posted October 15, 2014 Author Report Share Posted October 15, 2014 When you get the head skimmed you should get the upper timing chain cover that bolts to the head skimmed at the same time, just in case you didn't know.Didn't know that, makes sense. Will mention it to the engineer. Thanks for that VR6Pete 1 Link to post Share on other sites
