parki 2 Posted April 11, 2014 Report Share Posted April 11, 2014 Changed the MAF 3 days ago for new bosch unit and been running better than ever until today. CEL came on wasnt missing but power was all over the shop, if you hold the throttle the revs will drop and then pick up again without moving the pedal. Only got vcds lite but ran a chec and came up with 16497-Intake+Air+Temp.+Sensor+(G42)+P0113+-+35-10+-+Signal+too+High. At a bit of a loss where to start. full throttle it pulls better than it ever has in the 3 years i've had it but part throttle its all over the place. Any help at all appreciated. Link to post Share on other sites
Surreyvr6 199 Posted April 12, 2014 Report Share Posted April 12, 2014 That is what mine was doing when it had a faulty maf, unplug the maf and see if the problem stops, if so take the maf back to where you got it fromSent from my iPhone using Tapatalk Link to post Share on other sites
parki 2 Posted April 13, 2014 Author Report Share Posted April 13, 2014 Yep was the replacement MAF swapped back to original one while i wait for the replacement to be sent, dash is like a xmas tree but at least it drives. On the plus side i had more time when i swapped it back so gave the throttle body a spring clean and is now nice and shiney ready for when i manage to finally get a good MAF on! Link to post Share on other sites
