petrolhead 0 Posted December 17, 2008 Report Share Posted December 17, 2008 I have just forked out a fortune to fix the immediate problem of a stuck open injector. This is OK now but the car (OBD1) still has an intermitant problem of a dead spot at the bottom end of the rev range.It still ticks over OK but when I accelerate the first 1000-2000 revs, the car hesitates then pulls. It does the same if I decellerate the accelerate again. It pauses then picks up.Any ideas guys??It really pi"£$%"es me off!! Link to post Share on other sites
S.i.m.o.n 0 Posted December 17, 2008 Report Share Posted December 17, 2008 Try the blue temp sensor Link to post Share on other sites
ingham 5 Posted December 17, 2008 Report Share Posted December 17, 2008 check coil pack and leads Link to post Share on other sites
golfgirlvr6 0 Posted December 17, 2008 Report Share Posted December 17, 2008 it sounds like the coil pack! Link to post Share on other sites
petrolhead 0 Posted December 18, 2008 Author Report Share Posted December 18, 2008 Thanks guys,I have changed the HT leads in the last 18months so I don't think its those.How do I check the coil pack?What about throttle body and MAF could it be either of those also?? Link to post Share on other sites
Karr-Man 0 Posted December 18, 2008 Report Share Posted December 18, 2008 What about throttle body and MAF could it be either of those also??certainly possible... to check the coil pack either run the engine at night and look under the bonnet for arcing, or check whether all the plugs are sparking...do u have a later type coilpack or a dizzy??? Link to post Share on other sites
ez_101 1 Posted December 18, 2008 Report Share Posted December 18, 2008 when you turn your engine off leave your car for 10mins come back to it and if the coilpack is hot (not luk warm HOT) then you will need to replace it!! i had this happen on my old mk3 quite common i beleive!? Link to post Share on other sites
ip 0 Posted December 18, 2008 Report Share Posted December 18, 2008 My coilpack was buggered but no test I could find showed up the problem. Symptoms were exactly as you described. However, pack never got hot, showed no sign of arcing, had no visible cracks and measured fine compared to the values in the bentley manual. Eventually I replaced it out of desperation and hey presto, no more hesitation. Basically what I'm saying is that it is very difficult to test the coil pack and you'd be better replacing that than the MAF as the MAF does tend to be less prone to failure.If you want to rule out the MAF, give it a clean. It might not fix it but it should reduce the problem a little if the MAF is the item at fault. If no change, replace the coilpack.ip Link to post Share on other sites
petrolhead 0 Posted December 18, 2008 Author Report Share Posted December 18, 2008 Thanks again guys,I will try the coil pack tests as mentioned and clean the MAF.IP how much and where from for another coilpack?? Link to post Share on other sites
ez_101 1 Posted December 19, 2008 Report Share Posted December 19, 2008 I got mine from GFS original VW part for £30 Link to post Share on other sites
craggsy 91 Posted December 19, 2008 Report Share Posted December 19, 2008 My coilpack was arcing big time as some seen at the last national meet we had....could see and here it happening in daylight.So I took it off and it had grease and allsorts on it, so i got some wet wipes and cleaned it off and hey presto is running fine and has been since august Link to post Share on other sites
sparkyjr 0 Posted December 20, 2008 Report Share Posted December 20, 2008 I have the same prob at the moment got told to unplug the air filter sensor and has cleared the problem,is this going to have any problematic side effects as m due to drive up to scotland ?was also thinking of putting so red x in and maybe changing the plugs is this going to be worth it?? Link to post Share on other sites
